Format Necking for suspended activity
Dave Dodds
User offline. Last seen 5 years 17 weeks ago. Offline
Does anyone know if there is a way to show a physical split in the bar when an activity has been suspended? I am trying to show a blank space in between the first portion of work and the remaining portion.
Philip Jonker
User offline. Last seen 16 years 11 weeks ago. Offline
Unfortunately, It is not possible, the old open plan had that trick, the only way is splitting the activity in two, and puttting a lag in there
Dave Dodds
Phillip,
Thanks for the help. I may not have worded my question properly. What I am trying to do is to have the necked portion of the activity not visible in the bar. I wondered if you can format the neck to be transparent.
Dave
Philip Jonker
Hi Dave,
The facility exists, however it allows only one split, which can be changed, to a second split, but the first will disapear. You go the activity view, and then to dates, where it will give you the option of suspend, and resume, and set the suspend date, and the resume date. You also have to click on the barchart, left click, and set on the necking, on the bars.
