Resource Report by Activity
Rajeev Kumar
User offline. Last seen 10 years 21 weeks ago. Offline
Hi All,
Is there a standard report similar to the resource window, for each activity, just the budgeted quantity would be fine.I know there is a way by Matrix reports, but for than 30 resources, is there a simpler and easier way to tabulate all the budgeted quanity for each resource against all activities or selection of activities?
Dayanidhi Dhandapany
User offline. Last seen 4 years 15 weeks ago. Offline
you can use matrix report format to create it. If you Insert the "TTL(item) in the matrix report format column, you can get the resources title, so that you can find easy to read the resources description in full against each resource ID.
The otherway is to export all summarized resources to excel sheet and create the required report.
