Network problems
6 replies [Last post]
Stephen Fawcett-J...
User offline. Last seen 17 years 25 weeks ago. Offline
I am trying to open a file which is on the network but I keep getting an error "unable to lock target project" we have the access writes set to everyone and read/write access but still does not open. What am I doing wrong ?
User offline. Last seen 15 weeks 2 days ago. Offline
delete the reference to the target in p3 if you can not do that then
delete the target files from the folder
copy the existing file and give it the name of the project  that is the target project
open the project
Mulugeta Tsegaw
User offline. Last seen 7 years 38 weeks ago. Offline
i have got the solution by try and error.just i copied those files which have the problem to another folder and opened without problem.thank you
Mulugeta Tsegaw
i have tried to remove the target project but i couldnt again i get error messege "exclusive access denied".
Mulugeta Tsegaw
i am tring to open the some files of P3,other files are working, and i get an error "Unable to lock target project" what should i do to open these files
Thanks for your help but we have just found the P3 version downloaded is not working properly. Problem now resolved many thanks
Steven Oliver
User offline. Last seen 12 years 13 weeks ago. Offline
What happens if you unattach the target project ?. Sounds like someone has the target plan open in Exclusive mode
