Milestones met w/ negative float during leveling
J
Jose Frade 👤 Member for 21 years 1 month
I have no further hint on that. I guess it is related with the options you can set in the level comand window.
BR
JMFrade
C
Christopher Eitel 👤 Member for 20 years 7 months
Thanks for the input, Jose.
The constraints I’ve used are not mandatory. They will push (and subsequently show neg. float) when network logic delays them. However, your point has led me to another idea. Maybe the constraints will automatically NOT push due to resource leveling alone. In other words, the negative float reflects the need for additional resources in order to meet the dates shown. Unfortuntately, this is not what I want it to do. I’d like to find a way to make the program optimize the resources based on hitting the constraint dates.
Anyway, thanks again!
J
Hello Eitel,
I guess the constraints mentioned by you are set as mandatory. in this case P3 will not move them no mather the relations you have established. Instead, the negative floats are mentioned for the affected activities. Suggestion: release the constraints and recalculate again.
I hope this could help in any way.
JMFrade
Featured Partner
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
Akram Hammam Mohamed
Sagar Raut
