Printer Error
Rajeev Kumar
User offline. Last seen 10 years 21 weeks ago. Offline
Hello,
I recently changed PCs and reinstalled p3, 3.1 on my new OS, XP. I previously had Windows 2000. Now when I try to print anything from P3, it gives me a "Printer Error: General Error" message. All other programs print without any problem.
Has anyone come across this and could anyone point me into any useful direction
Rajeev
dr heidari
User offline. Last seen 6 years 36 weeks ago. Offline
thanks forthis post and topic
doctor heidari
dr heidari
doctor heidari
Adam Jems
User offline. Last seen 6 years 42 weeks ago. Offline
hey if you are facing any printing error then you can fix printing error status by following steps .this work 9 out of 10 times:-
  1. First of all, cancel any print jobs that may be in the queue.
  2. Switch off and restart the printer.
  3. Check the paper in your printer.
for more visit - brother printer support
Mohd Mahd
User offline. Last seen 17 years 24 weeks ago. Offline
i faced the same with HP and with PDF printers. Here is the results:
2 things should care about when printing from P3 3.1 on a XP OS (even with SP2).
1- as said install the P3SrvPk3.zip.
which will solve half of the problem.
2- go to the settings of any printer you r using and make it to send the prints as a Bitmap and/or adjust the spooling to print after last page is sent from P3.
and u will not have any further problem.
and good luck.
Hannes de Bruyne
User offline. Last seen 2 years 43 weeks ago. Offline
I think you forgot to install the service-package P3SrvPk3.zip
Hannes
