Budgeted quantity filter
Yves Trudel
User offline. Last seen 18 years 8 weeks ago. Offline
I’ve tried to set up a filter based on budgeted quantities, and I coud not find the field in the filter form. I have then created a custum field named BQ1 and made a global change to copy BQ into that new field, and then it worked partially.
My problem is that this custom field gets only the BQ of the last resource in the activity. Say I had 200hrs carpenter and 100 hrs painter in a given activity, P3 will give me only 100 hrs of the painter (considering this is the second resource)
Any solution?
PS I work in Primavera 3.1
Yves Trudel
Yves Trudel
I’ve tried both, but it looks like it had to be on Activity instead of Resource/cost
And all resources were added at the same time long before I tried this filter.
Steven Oliver
User offline. Last seen 12 years 14 weeks ago. Offline
Did you set up your CDI as an activity or resource ?
Raja Izat Raja Ib...
User offline. Last seen 13 years 39 weeks ago. Offline
do u already include your carpenter in resource? u should include all the resource account then u can add the resource using global change, if not this global change could not transfer as u instruct.
