Primavera P3 - compatible with XP?
7 replies [Last post]
John Paul Spence
User offline. Last seen 19 years 19 weeks ago. Offline
Hi, can someone please tell me if P3 is compatible with Windows XP Professional?
JP
Mark Hanford
User offline. Last seen 19 years 26 weeks ago. Offline
Yes - Works well. In a network environment you will need everyone on the network to be using Windows XP. Also we have had problems with Adobe Print, We had to install P3 service pack 2 and change some adobe print settings.
Frank Borcherdt
User offline. Last seen 7 years 50 weeks ago. Offline
John,
I can confirm what Sonia says....P3 3.1 with XP SP2 works well. There is/was a problem that Microsoft disabled the 16-bit subsystem in one of the hotfixes by removing the autoexec.nt file from the c:\windows\system32 folder causing ALL 16-bit apps to fail. Copy the autoexec.nt file from c:\winodws\repair to the system32 folder to correct this fault. Both the MS and Primavera knowledgebases have this info.
HTH
Sonia Thomas
User offline. Last seen 13 years 26 weeks ago. Offline
P3 ver 3.1 only works with Windows XP - and not earlier versions of P3. P3 works without any problem even if XP sevice pack 2 is installed..
(once I faced problem when installed XP SP2, where P3 was already installed..but lateron when I has to reinstall P3, it worked well, even though XP’s SP 2 is still there..)
John Paul Spence
Thanks. But if SP2 is installed on my machine - can i bring it back down to SP 1?
Dayanidhi Dhandapany
User offline. Last seen 3 years 35 weeks ago. Offline
It works well in XP environment with SP1, so far no trouble.
Bill Guthrie
User offline. Last seen 8 years 29 weeks ago. Offline
of course it is. works great together. but be sure and load up the p3 service pacs when installing
bill
