MATRIX TO CONTAIN 60 COLUMNS
13 replies [Last post]
Mohammed Muneeruddin
User offline. Last seen 6 years 12 weeks ago. Offline
HI
I AM TRYING TO MAKE A MATRIX REPORT CONTAINING 60 COLUMNS AND 15 ROWS. IT SEEMS ONLY 25 COLUMNS ARE ALLOWED . IS THERE ANY WAY OUT . PLEASE LET ME KNOW.
THANKS
HI PAUL
THANKS. THE PROCEDURE WHICH YOU HAVE DETAILED FOR HOW TO CONNECT THE ODBC TO EXCEL REALLY HELPED ME.
(REF : HTTP://WWW.EH.COM.AU
REGARDS
kamran hazini
User offline. Last seen 12 years 2 weeks ago. Offline
Hi Bill,
Would you please also send me a copy of the files to kamranhazini@yahoo.com?
thanks in advance.
kamran
Alan Midgley
User offline. Last seen 2 years 17 weeks ago. Offline
Bill,
Could also send a copy to myself at alangmidgley@yahoo.co.uk.
Alan
(Alan Midgley - planning manager for Bovis Lend Lease, UK)
Ravi Potwar
User offline. Last seen 4 years 5 hours ago. Offline
Hi Bill,
I am not aware of ProjMods, Can you Please send me the File.Please direct me How to Installed & Use further.
Ravi
Bill Guthrie
User offline. Last seen 8 years 20 weeks ago. Offline
Fully aware of the export inport capabilites of P3, but what I am referring to is the 2 downloads
one is called ProjMods
the other is Project, I beleive. both are xls files that are on some p3 installation disc, and at one time was available as downloads direct from Primavera.
The two files allow one to go into P3 through the database and work, for example, projmods allows you to export the activity code structure and work on it, change it and import it back into p3. awsome way to update code works.
emal me and i will zip and send to you if you want.
regards bill
Andrew Podolny
User offline. Last seen 1 year 11 weeks ago. Offline
Hi, Mohammed
The Crystal Report is more powerful utility (IMHO) than InfoMaker.
But you’ve to be familiar with database design in order to use it at full throttle.
You can read more about Crystal at: http://www.ripway.com/members/getfile.asp?file=\2005-3\268277\ProteanRep...
Andrew
Ravi Potwar
Henk,
Are you explaining about Export/Emport.Yes I know it is there Tools-Utility-Export-Emport,I was Thinking some other utility Power programme..?
Ravi
Henk van der Heide
User offline. Last seen 6 years 41 weeks ago. Offline
Ravi,
You can do this within the program P3win.
tools/project utilities export/import
regards
Henk
HI ANDREW
THANKS, INFOMAKER SEEMS TO BE DIFFICULT. WHAT ARE CRYSTAL REPORTS.
Ravi Potwar
Bill, Can you please explain more about power programme.I am not aware of it. Wher is available ,And how to Get it & its Utility
Bill Guthrie
Agres with JAco.
Most planners are not aware of the power programs that come in most P3 disc, basically downloads, that are p3 inport and export programs. With this, you can do almost anything in Excel then import back into p3.
Sometimes find it easy to work in xls then p3 and inport export. This is very good for 10 to 15000 activiy schedules that we come upon for large projects.
b
Andrew Podolny
I prefer to use Crystal reports v10 against P3 database.
With Crystal you’re able to produce well looking reports.
Or you may use InfoMaker (shipped with P3) instead.
Andrew
Jaco Stadler
User offline. Last seen 17 years 49 weeks ago. Offline
Why not do the report in xls. And use p3 Export Function.
