P3 performance
Dinesh Kumar Dama...
User offline. Last seen 8 years 42 weeks ago. Offline
Hi everyone,
Do you all have any problems running P3 on Windows XP operating system.I felt that running P3 on Windows XP is slower than running on Me or windows 2000 version.I have to wait quite a while before it can open,summarizes or schedules.
Please advice if any experiences or solutions.(We are currently running on P4 machines with 256mb ram).
Thanks & regards
Dinesh
Marc Borburgh
User offline. Last seen 11 years 3 weeks ago. Offline
Don’t know if it will help you all, but try this:
Goto your windows folder
Goto your system folder
Start the file W32mkset.exe
From the categories choose: Memory Resources
Then change the Current Allocation of the Cache Allocation from the default of 512 to 4096
This will reserve more memory for btrieve.
If you can’t find it in the system folder, check the system32 folder.
Hope this helps.
Philip Jonker
User offline. Last seen 15 years 48 weeks ago. Offline
Hi Dinesh,
I have found similar problems, and the answer is more RAM, depending on the size of the project (no of activities), you may need to upgrade to as much as 1Gb. On a previous projects I had the problem that I would run out of memory if I tried to print summarised barcharts. I was runnining 512Mb and had to upgrade to Gb to resolve the problem. It is a known fact that database resident programs run better with more RAM.
I am currently on a project where we a running Windows NT, aand am having serious conflicts with P3. Speed is very slow, and the program freezes regularly. Does anybody know of a cure?
Philip Jonker
Thank you for your replies.
I am not running P3 from the server.
There is no problems with the other applications normally as i have already tried that.
Dinesh
Dayanidhi Dhandapany
User offline. Last seen 3 years 31 weeks ago. Offline
Eventhough you have 250mb RAM, some opened applications prior to opening of p3 or during start up other applications may take considerable memory in windows xp, hence try to remove unnecessary applications from system tray or using msconfig.exe or so, then try to open p3 application you can see it will work faster.
Jaco Stadler
User offline. Last seen 18 years 2 weeks ago. Offline
Are you running from a server or from your hard drive.
