P3 on Windows XP
Jose Valdez Marcos
User offline. Last seen 3 years 15 weeks ago. Offline
Hi All:
I have installed P3 successfully in my new machine with Windows XP OS. However, I can’t print any layout to the network printer. Has anyone encountered this? What seems to be the problem? Appreciate you help. Thanks.
MK TSE
User offline. Last seen 4 years 37 weeks ago. Offline
Is it true, I use P3 v3.1 with SP2 on winXP pro over a year and haven’t meet this problem.
May I know the software configuration? Standalone or network installation? What’s the P3 folders path?
Ahmed Hamada
User offline. Last seen 6 years 45 weeks ago. Offline
Hi Guys,
this problem could be encountered when u r printing through print preview, but if u print through the printer icon on the top it will work.
regards,
Ahmed
Dinesh Kumar
User offline. Last seen 6 years 41 weeks ago. Offline
Hi Guys,
I am assuming that you have just installed your XP OS.
Even if you are using an network printer you have to install it to work for you.
If your network using a printer which is shared by a computer then do the following:
- Control panel>printer>network printer>browse for a printer and install it.
If your network using a printer which has IP address and stand alone then
- Control panel>printer>local printer>create port>choose TCP/IP> type in the IP address and install.
- Ip address usually available with system administrator.
IF you have already installed Acrobat® Distiller then you can print becasue it create a PDF printer for you.
Dinesh
Venkatasubramania...
User offline. Last seen 11 years 31 weeks ago. Offline
I am also faced the same problem. When I try to see the print preview, i am getting an error message "no printer is installed". The printer is installed on the network. I could able to print on Adobe Acrobat. I dont know why it is not getting printed on on the network printer.
Ravi
