How to link Access to P3?
Erkan Polater
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
Thank You for your valuable info.
Thank You.is a very useful info. and i am trying now.
On the P3 knowledgebase
Bulletin Number: 200011616333
You need to install the Pervasive 32-bit ODBC driver that Primavera sends out, i.e. "Pervasive Software ODBC-32" version 2.04.02.10.
1. See Technical Bulletin 200052692630 - "Setting up SureTrak v3.0 for 32bit ODBC", and Technical Bulletin 1999330113639, "How to install the Pervasive 32-bit ODBC drivers" for instructions on installation and configuration.
2. If using SureTrak, save your project as a Project Groups type project if you haven’t done this already.
3. Go to Tools, Update Data Dictionary to create your *DDF files .
4. Create the Data Sources for the SureTrak projects you want to work with through the 32-bit ODBC driver in Control Panel.
5. Make sure that the project is not open in SureTrak or P3.
6. In Microsoft Access go to File, New Database to create a new database.
7. Give the database a name.
I hope this helps
There is an add-on made by Primaplan called Flint that allows you to do
this, have a look at Primaplan.com
Try This Site
Link
