Global Change Resources retaining "Budgeted Units/Time"
David Cartwright
User offline. Last seen 3 years 12 weeks ago. Offline
Good Morning, I am trying to do a Global Change to change some resource Name ID's to a new set of resources.  When I do my original Duration on the Resources tab is retained but the "Budgeted Units/Time" value changes back to the default of 1.  Is it possible to preserve the duration and budgeted units/time when I change reseources?
Thank you in advance
User offline. Last seen 25 weeks 4 days ago. Offline
Hi David,
Check your setting on User Preferences --> Calculation Tab. Make sure that "Preserve the Unit, Duration...." is tick. See below:
User-Preferences-Calculations-Tab
Hi Jose,
Usually it happens if the Material or Non-Labor or Labor resource ID is already existing on the other users P6 database but diferent resource name. If the option for import XER resource is set to Keep Existing instead of Update Existing then this will not overide the existing resources.
Jose Ronald Lingahan
User offline. Last seen 2 years 42 weeks ago. Offline
Good day! I trying to save my XER file in USB(Pen drive) to share it to another user but the materials resources is not preserve/display to the other user?Labor resources is ok no problem with that? Anybody please share any solution to this materials resources which is missing to other users...Thanks
make sure that the duration type is set to fixed duration and units/time
the other option is to export them to excel run your global chnage and then import them back in
