Alternatives to lags and dummy activities
Brian Walkin
User offline. Last seen 36 weeks 4 days ago. Offline
I haven't seen a good answer to this in the general forum and would really like to know the accepted theory or best practice.
Example the engineering specification for a piece of equipment is available in M2, lets say it happens to be one of the first items to be designed. The procurement process means a purchase can be made in M4. The lead time is 4 months and so it will be available for delivery to site at M8. I only need to install that item in M16.
The client spec does not let me use leads and lags and the us of the "As late as possible" constraint should not be used. I dont think a "start after date" constraint is approriate.
What is the proper way to schedule this that isn't a work around.
Brian.
User offline. Last seen 2 weeks 3 days ago. Offline
add the activites that get you from engineering to installation
User offline. Last seen 32 weeks 2 days ago. Offline
Hi Brian
Set up a sub chart and put the tasks and duration into a procurement cascade.
Then link the last task to your installation task - you will have some float availabl.
Best regards Mike Testro
