Importing and Exporting from excel to P6
Suhaila Tsu
User offline. Last seen 1 year 11 weeks ago. Offline
Hi everyone
PLease explain why some data imported from excel file cannot be read in P6.
What is the reason. How P6 read or store data?
What are the things that should be done to the data in order for us to succesfully import to P6.
THank you for the explaination in advance.
User offline. Last seen 16 weeks 6 days ago. Offline
for the most part this is true but some dates can be imported.
But generally speaking it is beacuse they fields are calculated
What is it you want to import
Also you can use SDK and import anything
Suhaila Tsu
Hi Santosh Bhat
Meaning only certain field in P6 can be loaded in excel and then imported back right?
Thank you Santosh!
User offline. Last seen 40 weeks 3 days ago. Offline
The best method is to export out a sample of data, continnue populating the list and then import. Note that any field exported with a (*) cannot be imported - usually becuase this is a calculated field - such as dates.
