Glass Facade - construction sequence and timing
laith batarseh
User offline. Last seen 5 years 49 weeks ago. Offline
Dear All With regards to when to start glass panel installation at facade, let us assume that the internal Partitions is block work and plastering can we install glass facade before starting of internal block work or it has to be installed after plastering My doubt that if we start glass facade before then it will get dirty after we do plastering
laith batarseh
thank you all for your reply, appreciate it
Laith Batarseh
User offline. Last seen 11 weeks 4 days ago. Offline
Hi Laith
With glass facade do you mean Windows built into the ecternal wall or a free standing glass facde fixed to the structure.
With windows you can use timber sub frames to form the openings and plaster up to sub frame with a stop bead.
The windows than have to be fixed from the outside.
If it is a fre standing facade then it is the structure that determines the start date because the building has to be checked for line and level before the secondary support frame si fixed with the correct shims. Normally there is no interface with a plaster finish.
zahid shaikh
You can start internal blockwork and plastering works. But only the blockwork terminations work to the Glass facade works will be pending. You can update the activity too 99% or something like that, Until the Facade is closed then you can complete your blockwork termination.
User offline. Last seen 15 weeks 2 days ago. Offline
if all you are worried about is getting dirty then protect the glass with plastic or some other material.
Some considerations depends on your climate where you are performing the  plastering work the ambient temperature must be higher than 40 degrees. Usually you want the building enclosed and weatehr tight before you begin finish work such as plastering.
