Using P6 Database in Excel
F A
User offline. Last seen 6 years 51 weeks ago. Offline
Groups: GPC Qatar
Hello All,
I'm trying to have p6 data in excel for various reporting purpose. Instead of copy pasting i decided to use Microsoft query to access the p6 database tables.
I'm having problems to identify the specific tables i need to use. I found Task table quite helpful but it doesnt display baseline dates or progress. I assume i need to join to two tables to get the result i need. But i have no knowledge of my project number in the table. the Proj_id which i knw is not displayed in table such as Activtiy.
HAs anyone worked on something similar. Could you provide some guidance on it.
F A
User offline. Last seen 21 weeks 5 days ago. Offline
have you tried using sdk ? and the assoicated spreadsheet
Tom Reichner
User offline. Last seen 5 years 35 weeks ago. Offline
I suggest you investigate building custom P6 reports. The more recent versions of Primavera starting with Release 8.1 give greater flexibility in creating P6 reports to pull information out of the database and organize as you wish. Once you have created a P6 report the way you want it you can then export it as a csv file and save it in Excel. I have built more than a dozen P6 reports so far, and will probably create others in the future.
Tom Reichner treichner@yahoo.com
F A
Groups: GPC Qatar
Thanks Zoltan. But the problem here is it's a huge database with lots of projects. How to identify the project u need in the database. Each project is assigned a projectobjectid in the database. Is there a way to identify that. Has anyone tried using the p6 database in excel. Appreciate any help.
see if my post in the other forum helps
http://pmsite.com/forums/viewthread/3373/
