wt % age @ smry level by USER DEFINED FIELD
AHMED HASSAN
User offline. Last seen 13 years 46 weeks ago. Offline
Dear All
I want to calculate weighted %complete of cost at summary level....when i define the user defined field and enter the criterea in the global change system is calculating individual activity %-ages but then adding them all on the summary level which is exceeding 100%......
kindly advice what options should i use to get weighted %ages at the summary level
Ahmed
Safak Vural
User offline. Last seen 4 years 43 weeks ago. Offline
Dear Mr Ahmed,
I belive you are using P3. There is no way to subtotal a custom defined value as a weight in a project.
My humble suggestion will be:
-Add cost % as resources with a proce as "1"
-Add a custom data item for % also.
-Use Global Change for transferring value from resource to custom data item.
-Use "Resource/Cost Percent Complete" as a column in the layout in order to have correct subtotal values of % in group or project totals.
Please be carefull about decimal restrictions of P3 (1 decimal for % but 2 decimals for "Custom data items - precision" or "resources". SO it will be healthy to use only 1 decimal in resource (or use resource as will sum up 1 million units ).
You can create more accurate reports in Tools-Graphic Reports-... but i dont believe it is a good manhour waste in order to get layouts that are visually crap and requires so much attention.
Safak
AHMED HASSAN
Dear Mr. R. Catalan,
Really gr8ful for ur advice & time.
This option I already know I just want to do the same by using the user-defined fields for many other calculations. I have been able to do so but I am not getting the summary at the top as the system is giving simply the addition of all the values under the perticular head.
I will really appreciate if someone could provide me with the solution.
Ahmed
R. Catalan
User offline. Last seen 13 years 7 weeks ago. Offline
Ahmed,
Cost load your schedule. Percent complete and costs (both planned and earned) are automatically shown after cost-loading the schedule.
R. Catalan
