CSI for Pre-construction and Post-construction stages
Yasser Elyosefi
User offline. Last seen 5 years 22 weeks ago. Offline
Hello Planner,
CSI Master format is mainly built for Construction stage.
Is there CSI codes to define Pre-Construction activities, such as Consultants selection and appointment, Evaluation and Award, Eng. and Design (Concept, Schematic, DD, CD) , Tendering, Bidding and Award process, Procurement (of contractors), Procurement (of Materials and Equipments ), etc.... as well as Post-construction stage such as testing, commissioning, handing over, snagging, liabilities, etc…
Yasser
Ronald Romero
User offline. Last seen 1 year 37 weeks ago. Offline
Yasser ,
download the CSI on this page http://www.csinet.org/s_csi/docs/9400/9361.pdf
Cheers and Keep on planning
Yasser Elyosefi
Hi Rami, Ronald,
I’m using CSI Master Format 2004 in which Div 00 is not there. The first division is 01.
Ronald Romero
Hi Yasser,
Your dillema is the same as mine since i’m working with a project management company. I use the procurement and contracting requirement from div 00 as a preconstruction Division. I don’t use any division for post contruction because i usually put there testing and commissioning, snagging and demobilization and the rest of the division fall within the construction stages.
Hope this helps you a little bit.
Rami Al Haddad
User offline. Last seen 5 years 46 weeks ago. Offline
hi,,, depending on the format you are using which i suppose is the 1995 format, look in Div 00!
regards,
rami
Yasser Elyosefi
Hello Planners,
What is up?
I didn’t receive any single response from any of you for my question below.
Is the question is too easy or too difficult?
Yasser
