first of all, please dont call me Sir, cost monitoring is quite difficult to implement especially if you dont have full access to the data/information needed. I suggest that you concentrate on schedule monitoring (for a start), in other words, you find out how task durations were derived, and if the project is workable using the estimated task durations (based on what/where?). For cost data, you can use excel, you can also generate s-curves from excel.
17 years 7 months
Member for17 years7 months
Submitted by Ericson Flores on Thu, 2008-05-15 04:25
Thanks for the advice sir.Sir may i know what program you are using?Are you using P3 too in monitoring? I havent tried using the program to cost monitoring yet,isnt it difficult due to actual inputs of actual cost within the span until the project is done? In addition, how does the software creates the accomplishments s-curve,i know its by weights but how?...you know pms cannot understand this kind of program generated reports and sometimes this makes me confused too. Thanks!
Eric
17 years 7 months
Submitted by Ericson Flores on Thu, 2008-05-15 04:09
Thanks for your reply. You see im also a newbie in P3, and Im planning for almost 8 months now. Sir may I know about this "earned value" your talking about? I think i somewhat knew something about it but could you explain it to me further sir.You know it would be of great help for me and it will be highly appreciated.Thanks!
Eric
19 years 5 months
Member for19 years6 months
Submitted by James Griffiths on Wed, 2008-05-14 07:17
19 years 1 monthRE: More Improved way of project monitoring.
17 years 7 monthsRE: More Improved way of project monitoring.
To sir Anoon,
Eric
Sir James,
Eric
19 years 5 monthsRE: More Improved way of project monitoring.
Have you used a method called Earned Value?
James.
I believe that the two most important matters in a Project are cost and time, so monitor from there.
