Production rates
Mirza Imam Baig
User offline. Last seen 6 years 13 weeks ago. Offline
Hello Experts,
Can any one/ Moderators explain me, what is the basis for the Production rates mentioned on PP? As per MEANS Heavy Construction Cost Data, the Production rates are defined wrt the crew assigned to it. Here what is the basis.
Imam Baig
Francis Moyalan, ...
User offline. Last seen 5 years 15 weeks ago. Offline
Imran,
You have poised the right kind of query,
I was about to ask the same query, if the productivity rate for block work ( thermalite block is given x sq m)what does that mean?)
Is that the productivity of a mason with a helper?
Can you (moderator) explain this? Since generally productivity rate is given for a trade ( for e.g. a mason for block work can complete 100 sq m per day with a helper with him),
Can you give the rates based on the trades,
francis
