Key Performance Indicators
17 replies [Last post]
Andrew Owenson
User offline. Last seen 17 years 10 weeks ago. Offline
Hi Guys
I have been asked to produce a set of KPI’s for Planners. They will be used to monitor performance and will be used as a basis of bonuses. This system will be intended to be used in both tender and construction programming. I have thought of a few
Team leader satisfaction with the overall service provided
Team leader satisfaction with product
Programme delivery (within agreed timescale)
Programme accuracy
Progress moniotoring
Any ideas
Andrew
Amendra Jagoda
User offline. Last seen 17 years 32 weeks ago. Offline
Alex,
You are truly correct, if you plan for productions/manufacturing, in such case, your goal is to achieve the target out put.
But Construction planning and monitoring progress is different. It is generally through a long period, a year or two or more. During such periods, many unforeseen condition may be generated due to variations, work stoppages, force mageure, submittals and approvals, procurement etc. At the end of the day, to create a cause and effect analysis to adjudicate who is resposible for each delay (employer,engineer or contractor), use of KPI is one of the important estimation method, that you can justify your assessment.
Alex Wong
User offline. Last seen 12 years 15 weeks ago. Offline
Groups: TILOS
Dear All
For my team members I prefer look at outcomes and result rather than KPIs
I looking at KPIs is processes and outcomes is output.
Input -> Process -> Output
Effort -> Performance (KPIs) -> Result
Some time excellent proceesses do not garrantee excellent outputs. So, my staff I would concentrate on the outcomes and outputs.
Alex
Mohammed Abo El Magd
User offline. Last seen 15 years 45 weeks ago. Offline
Andrew
If the deviation between original and actual is 10 to 15% ,That would be acceptable and a success for the planner. If the percentage exceeded this range we have to investigate the reasons for this deviation if it were planning problems or execution problems. It should be a wise investigation not just pointing fingers to each other. The main goal from it should be avoiding such problems in the future.
Andrew Owenson
Mohammed
How would you be able to differentiate between the accuracy of the planner’s programme and the site’s delays, not claimable delays but mistakes, lack of coordination etc
Andrew
Andrew
Oh,,, now I got it. I thought you mean how applicable was the plan and what was the deviation between actual and the original plan, is it with in acceptable range or beyond that. By the way, you could consider that one of your KPI points.
Sorry for the delayed response
Andrew Owenson
Mohammed
Sorry I missed your point regarding the 4th point - accuracy
What I meant by this was does the programme accurately reflect the scheme - the scope on the drawings, bills etc. I take on board the general comment by everyone about peoples perception rather than fact. My concern is that what else can a planner be measured against?
Andrew
Andrew Owenson
Clive
100 lines - I must behave myself in class.
Andrew
Clive Randall
User offline. Last seen 17 years 29 weeks ago. Offline
Andrew
I stand corrected
Chris Oggham
User offline. Last seen 10 years 27 weeks ago. Offline
Andrew,
You’re right, there is nothing wrong with having Key Performance Indicators, sometimes they’re called Key Success Indicators showing just how well you’re doing your job. Whatever you decide on as the KPIs you should try to ensure that they are SMART, Specific, Measurable, Achievable, Realistic, Time-related.
That way you avoid any recriminations about unfairness, or dependence on somebody’s opinion, which can cause problems.
Chris Oggham
Andrew Owenson
Clive
Its a contractor. The KPI’s will be used as part of the appraisal process. What is wrong with having key points as a measuring device? People who are doing their job to their best abilities should not be worried about being assessed. I Personally have no problem being assessed via a stuctured appraisal process.
Anybody else got any thoughts ?
Andrew
Clive Randall
Andrew
Have they given up on staff performance appraisals and returned to the battery hen method of management
Have u obtained your slopy dickensian desk yet
Is it time for you to leave and get a new job
Is this a consultant or contractor
Clive
Steven Oliver
User offline. Last seen 12 years 32 weeks ago. Offline
How many points do I get for Insolence, Intolerance and Sarcasm ?
Sukumaran Subaram...
User offline. Last seen 9 years 50 weeks ago. Offline
Groups: GPC Malaysia
Well general appraisal is always better than specific appraisal, i.e:
a) Communication
b) Team work
c) Efficiency
d) Capability
e) Understanding
f) etc.....
Management can use the general info for salary increment and bonuses payout. As for promotion, management can use the specific info as you mentioned earlier.
Regards.
Andrew Owenson
Thanks for your replies
I was thinking that maybe I could use most of the KPI’s for both Precon (tender) and Construction phases.
I would really like to have about ten points of reference though. ?
Andrew
Shah Shams Alam
User offline. Last seen 13 years 33 weeks ago. Offline
Andrew,
Indeed these are good monitoring points. Mohammed is right in pointing out that first two points depend on human mood, but they are very essential. you can also consider taking feedback from end user of the plans. I mean execution team or field personel.
Andrew,
These are good points, but you should give low weights to the first two points, that both of them depends on human moods which is not always stable.
For the forth point, How do you plan to measure the accuracy?
Steven Oliver
What ?
Someone wanting to monitor what Planners are doing?
We cant have that.
