Excel Line Graph Problem
6 replies [Last post]
Alex Costaras
User offline. Last seen 8 years 44 weeks ago. Offline
I’ve want to swap round the X and Y axes on an Excel Line Graph produced by the Graph Wizard. I.e. I wish to plot the X data on the Vertical Y axes and the Y data on the horizontal X axes. Any ideas how I do this, witout altering the origical data from which the graph is drawn?
Sukumaran Subaram...
User offline. Last seen 9 years 36 weeks ago. Offline
Groups: GPC Malaysia
Alex,
At present there are not many choices and flexibility in Excel. You got to bear with Scatter XY graph with values on both X and Y axes.
Else, if you got AutoCAD using value and category try to draw the graph manually. Maybe it will help you.
Good Luck.
Alex Costaras
Hi, sorry but these still have the X axis as the category axis and the Y axis as the value axis. I need to turn them round so that the categories appear on the verical axis rather than the horizontal. Thanks anyway
Raja Izat Raja Ib...
User offline. Last seen 13 years 44 weeks ago. Offline
hi there,
maybe u can see the sample as per attached..
Free Image Hosting at www.ImageShack.us
is it like the one u said...i just try to guest your needs
Alex Costaras
What I’m trying to do is make the Y axis a Catagory axis and the X axis the value axis (By default they are the other way round)for line graphs (not scatter graphs, which have bot X and Y as values axes). Anyone have any suggestions?
Alex Costaras
Sorry for being dense, but what do I change it to, as the Y data is automatically calculated from the data range.
Go to: Source Data > Series tab > change the range of cells at Values and Category (X) Axis Labels.
This will swap the X data to Y axes and Y data to X axes.
Cheers!!!
