Well these people called QSs i view them as helpers to Engineers in any construction environment. I worked for 3 years in Africa and used to everything that a QS does. BOQ, costs, estimates, projections etc and we still used to deliver our projects on time. Now i am working on a project where i would rather not worry about how to come up with an actual cost but would rather have a QS do it for me as i am too busy scheduling thousands of activities and adding more programs each day.
The verdict is we need QSs to their bit, but they are no comparison to planning engineers.
The problem with this moderation system, is that we never know what we said, hope they are keeping a record of it, as they would probably have wiped a few of Churchills speeches, if they were in charge at the time. I think it is the ultimate in censorship, and they would probably have found a way to ban any discussion on "the Lord of the Rings" by JRR Tolkien, who was a SA, and grew up with and in the same town as my grandfather. These so-called moderators are a bunch of ignoramuses, who will probably try and delete this posting, I appeal to PPadmin, who has a sense of humour, to overide the moderators. At least contain your dogs of war, et tu brute, till a few guys have read this.
This is a classic posting, hope it is not deleted, as I will copy it and paste it till all interestrd parties have read it. Will do this on a regular basis, so that all can read.
“Having said that, is sad but many have progressed to doing Contracts Admininstration, Contracts Preperation, Costing of a project and they have only high school and little or no University at all, and are trying to do a Professionals job.”
I think your view about Engineers is rather jaundiced, Bill. I know a few Engineers who have been to University, and even yet they can’t spell or punctuate properly!!
Otherwise you will end up with an open ended plan subject to claims, variations, extension of time and other contractural issues (in other words to perpetuate QS existence and reason for living).
Planning for visionary, doers, leaders or engineers IMHO.
By the way, why use those SMM, why not try CSI masterformat.
I am not derogatory about QS’s merely pointing out that engineers have or had (in the past) the technical experience to solve problems.
As for your claim that engineers cannot produce bills of quantities, I beg to differ, as I was producing these on a daily basis in 1972, do you know how to survey a road, then to put the survey data onto a drawing, and then design the road with the correct geometrics, including the stormwater drainage, foundations, and then do a take of of cut and fill, and produce a detailed B0Q? When an engineering problem occurs on site how do you solve it, if by law you have to be an engineer. So why not understand your discipline, and it is only money at the end of the day, lets fire all the engineers, and start a new discipline ie Planning QS’s. Or maybe the Bean counting fairies.
I replied to a thread about tall buildings just now, maybe have a look at it.
No offense meant, but I know quite a few QS’s who will agree with me, and also some who have taken the time to learn, and have become good schedulers.
I am astonished that you seem to think that QS’s are only limited to architectural building works; you need to get out a bit more.!! QS’s are fundamental to the financial success of many types of projects, including roads, bridges, heavy civil works, marine works, M&E works as well as general building work.
And who do you think produces Bills of Quantities in the first place? Certainly not an engineer (or at least not if you want any accuracy!!), and a QS will generally produce a more comprehensive and accurate Change or Variation Order Request than any engineer.
This in-house contractor mostly measure the pogress based on financial value ie. How much value of works were completed at site for the past month?
Usually, when the disaster strike than the contractor start to crack their head. They dig back the old files and look for the delaying events that hamper the work progresses at site and work out the schedule for EOT claim.
Basically, the Planner having a tough time with the local contractor to proof that planning is an important field in contruction industry.
I fully agree with you that engineer need to concentrate on solving the problem, if possible within the budget. Or else, if left with no other choice, need to exceed the allocated budget and try to recover it from other part of the work.
However, in general, for any DEVELOPER/investor , money is the key concern. Though the DEVELOPERS/investors very much rely on the QS to know about the financial position every now and then, they tend to lose focus on the progress. However they need to remember that slippage in progress leads to losing money. So I can say that when the planning is given due consideration and serious respect is given to the schedules prepared by the planners, the QS job will become a routine. Only when the developers/PMs fail to respect the plans/schedules, they turn towards the QS. So it is the planner who helps to prevent the disease and QS plays lead rule in the curing stage, once the disease had run deep.
Agreed with you on the differences for Planning Engineer and QS job scope. Basically, the nature of job is controlling the needs for Planning Engineer and QS.
As you mentioned, the demand is very high for QS in bulding industry. As for Planning Engineer if there is a necessity (ie. project value more than 100 million) than the contractor will hire the Planner. If not the Project Engineer end up doing the scheduling work.
The worst thing is when the project is an in-house project (client and contractor are managed by same management), the contractor will never bother to develop a realistic schedule. Contractor will create a schedule for the sake of contract requirement and the baseline will be pasted on wall (as a wall paper) without any changes until the end of project.
In term of academic, the Planning and QS papers are part of Construction Management / Project Management studies. Never come across that Architectural faculty is offering QS paper because architectural itself is a specialist field.
The bottom line is that there is quite a vast difference in training, and normally quantities would be part of an engineers job, however, QS training from my experience is more or less restricted to building work. In most instances at academic institutions QS is part of the architectural faculties.
Hi clive
Tell me, I probabably was also moderated
Hi guys,
[Deleted by Moderator.]
Agree!
Didnt Bill Gates flunk out of University and fail to graduate?
Stuart
www.rosmartin.com
How did Bill Gates created his Microsoft? Is he a Planning Engineer or a Q.S.?
Quote from Bill:
Stuart
www.rosmartin.com
Hi Clive,
Thanks for your insight; but believe me, not all QS’s are reactive.
On the contrary, many are forward-thinking and are pro-actively engaged in ensuring the success of projects world-wide.
Stuart
www.rosmartin.com
Hi Clive,
I agree with you, QS a no... no... in planning.
Charlie
Hi Philip,
Thanks for your clarification; I am suitably impressed.
Stuart
www.rosmartin.com
Hi Stuart,
Philip,
Stuart Ness FRICS
www.rosmartin.com
Philip,
Regards.
Hi Philip
Ravi
What is answer if you have a problem of a technical nature hampering progres. Do you want to solve it or work out what is the financial implication?
Regards.
Philip,
What is the bottom line? Planning Engineer and QS have two different entity or both can cross over to do each others work.
Regards.
