Raft Foundation Construction
8 replies [Last post]
Alan Burns
User offline. Last seen 19 years 25 weeks ago. Offline
Hi all,
Does anyone have any detailed information on what they view as the correct sequencing for the construction of a raft foundation, the project is a £6 million steel framed school. There is great debate in our office at present!!
Hope someone can help,
A.
Darrell ODea
User offline. Last seen 19 years 1 week ago. Offline
Roger,
Would you believe that I knew someone would support my comment. Don’t know why.
Pre-fabricate everything. They had the right concept in mind in the 60’s, with system building.
D.
Roger Thomas
User offline. Last seen 14 years 19 weeks ago. Offline
Many a true word said in jest Darrell. The foundations for the cills in the Thames Barrier were constructed in dry dock and then floated into position.
Darrell ODea
Don’t forget to make it out of wood or plastic, it floats better that way.
Prefabricate it off site & just deliver & position.
QED
Dayanidhi Dhandapany
User offline. Last seen 3 years 46 weeks ago. Offline
To avoid all these doubts of underground services/deep fdns etc., develop the construction schedule sequence based on the construction drawings.
Asif Anwar
User offline. Last seen 8 years 35 weeks ago. Offline
Don’t forget to allow for any temporary works required especially if it is a deep foundation.
Asif
Jaco Stadler
User offline. Last seen 18 years 17 weeks ago. Offline
What about underground services. Ducts etc.
A Simple rule is from bottom to top.
Alan Burns
Think I may have won the arguement my friend, thanks!
If you have construction drawings for the raft foundation(for an example), you can develop the construction sequence.
If you have divided the raft area into some zones, then for any zone the probable construction sequence would be
Excavation->Blinding->Reinforcement->Sideformwork->Concreting->Curing->RemovalofFormwork and then based on the design/drawing if you have steel column works, you can develop the program further as provision for fixing of base plates(before concreting), steel column members etc...............
