Display '%' Sign/Symbol in User Define Filed
N
Nilesh Jain 👤 Member for 6 years 5 months
Hello everyone,
I'm trying to display the percentage difference between the current update and the previous update using user defined field and later running store period performnace followed by two global changes.
I'm getting the results in number without '%' sign/symbol. However, if there anyway I could get the result with '%' sign/symbol in the uder defined filed?
Thanks for your help in advance.
Nilesh Jain
N
Sorry for the formating problem but using Text UDF and in glocal change selecting '&' Operator and '%' Parameter/Value will work.
N
Hi Zoltan,
Thanks for your help. I have found the solution to get % symbol/sign and I hope this could help to other people who might be looking for the solution.
1. Create another UDF: Data Type Text (Call it % Progressed for this Period)
2. Global Change:
Then       Parameter                                      Is                     Parameter/Value                    Operator          Parameter/Value
            % Progressed for this Period               =                  UDF (Choose UDF you want to       &                        %
                  (Created in Step 1)                                             insert % sign)
3. Apply Changes-> Commit Changes
4. Insert UDF from Column and you will see % sign with number.
Done!
Abkar Bannayan
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
GeoVe
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
