To all Engineers who use the Primavera's Magic Tools Family
Mohammed Ali
User offline. Last seen 2 years 47 weeks ago. Offline
To all Engineers who use the Primavera's Magic Tools family
Now you can update all tools from these links:
SDK Magic Tool:          You can update it from this link
http://www.mediafire.com/file/ougb7bfikqdae9n/SDK_Magic_Tool.xlsm/file
XER Magic Tool:          You can update it from this link
http://www.mediafire.com/file/xo2ps4q5erc281q/XER_Magic_Tool.xlsm/file
XLS Magic Tool:          You can update it from this link
http://www.mediafire.com/file/7ill1qgdz9lwntx/XLS_Magic_Tool.xlsm/file
SQL Magic Tool:          You can update it from this link
http://www.mediafire.com/file/9wioa7aby27pcm4/SQL_Magic_Tool.xlsm/file
Mohammed Ali
You can download the 37 Excel files which illustrate exactly how you can use the SDK Magic tool from this link.
http://www.mediafire.com/file/o1g4j8qw7rmk3pg/Primavera_SDK_Samples.zip/file
Most of the files have three sheets:
The first one represents the current status in Primavera.
The second sheet includes the required changes which may be  adding or removing or modifying.
The third sheet makes a comparison to assure that all modifications have be done by the SDK Magic tool as required.
You can also update all tools from these links:
SDK Magic Tool:
XER Magic Tool:
XLS Magic Tool:
SQL Magic Tool:
Mohammed Ali
Hi Murali,
You should see the last 6 minutes of this video
https://www.youtube.com/watch?v=YjVqyzOCgSE
to know exactly the required settings to use the SDK Magic Tool.
In general you should use Excel 2007 or 2010 where it must be 32 Bit.
The SDK Magic Tool works only with Oracle and SQL database.
Primavera SDK development kit must be installed.
You should create an ODBC connetion for any database you would like to view or modify.
Try to use the second part of the tool and send me any error message as a screen shot to search for a solution.
Murle Krishnan
User offline. Last seen 5 years 10 weeks ago. Offline
Groups: GPC Qatar
Hi Mohammed,
Thanks for the valuable tools. However, SDK magic tool is not working as it shows error when i opened in first instance. Even after it got opened when i click open table after selecting the list of table from drop down menu the excel file got closed automatically. Is there is any solution to open this file?
Murali
Mohammed Ali
Russ Tomb
What is the magic tool?
