Problem importing activities from excel
Alexander Macintyre
User offline. Last seen 5 years 28 weeks ago. Offline
Hello all,
Here is the issue im facing;
I made my activity list in excel with each WBS codes with the exact codes in Primavera. I then made one new activity in Primavera, exported the xls file, added the "Activity ID", "WBS code", "Activity name" and "Duration" of each actvity, and made sure the "Duration" was formatted to text, but when I import it I get an Error message saying';
Excel Import log started : 14-Feb-19
INFO: Importing Global Data...
INFO: Importing Project Data...
INFO: Importing:
WARNING: TASK: Failed to resolve foreign key for field WBS Code with value NEWPROJ-7.Cons.Allb.Resd.St-A.Z-01.A-A1.Sust.Cnwr. Field cleared.
It has this for what I belive to be every WBS
Then it says;
ERROR: target_start_date is null for TASK ActivityID: St-A-Z-01-A-A1-3-0, Project: NEWPROJ-7
For what I assume is every activity.
I hope you guys can help.
Alex
User offline. Last seen 25 weeks 5 days ago. Offline
double check the wbs code
Kirill PM
User offline. Last seen 5 years 11 weeks ago. Offline
it becomes easier with additional tools:
https://youtu.be/1e-AAxCMAis
Alexander Macintyre
I found the solution!
If you schedule the project and give it a data date before importing, the activies will import sucessfully.
