Cross-schedule Critical Paths
Ashley Greatorex
User offline. Last seen 7 years 38 weeks ago. Offline
Hi all,
I was just wondering if it is possible to see cross-schedulecritical paths; e.g. if I have a project split into 3 schedules, which are linked together with inter-project dependencies, is it possible to see 1 critical path for the whole thing?
Ash
User offline. Last seen 3 weeks 6 days ago. Offline
there are two options
option #1
filter for longest path
option #2
create a global code call it Mypath
make the code value MP for my path
add this column to the view
filter for the last activity in the schedule
look at its predecessors and look for the one that is checked DRIVING AND CRITICAL
now in the predecessor window highlight that activity and then click on GoTo
keep doing this until you get back to the data date or the start of the project.
now in the column that you just added (MYPATH) put in the code MP
now do a fill down for all of the activities that are on your screen
now filter where Mypath equals MP
now you have it
David Kelly
User offline. Last seen 2 years 17 weeks ago. Offline
This is one of the scheduling options.
1) when you open more than one project, the scheduling options for the group are determined by the "Default project" (set under the Project main menu tab)
2) That Default project should have the "Calculate Total Float" option set for "Opened Project"
You now have a single scheduling entity, no matter how many projects are open
David Kelly
