Stacked Histograms in P6 Professional
Emily Foster
User offline. Last seen 2 years 49 weeks ago. Offline
Here's a great primer on how to do stacked histograms in P6 Professional http://ow.ly/rGcj308pw8v
Joel Roberts
User offline. Last seen 45 weeks 5 days ago. Offline
Great Resources.
Joel Roberts
Here is another additional resource on histograms and stacked histograms: https://www.schedulereader.com/blog/understanding-primavera-p6-histograms/
David Kelly
User offline. Last seen 2 years 40 weeks ago. Offline
Couple of problems with P6's stacked histograms.
"At Completion Units" is the only choice, "Remaining" and "Forecast" might be more useful
The filter to identify each data range only lets you select from attributes of the Resource Dictionary NOT the Resource Assignment. This is very restricting, for example you might be using the same resource for regular maintenance and for turnaround activities – you can’t colour these differently. Indeed the same resource on two different projects cannot be coloured different.
 And of course you can't show the data range table under the histogram.
Normal 0 false false false EN-GB X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:8.0pt; mso-para-margin-left:0cm; line-height:107%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
Kathy Castle
User offline. Last seen 6 years 28 weeks ago. Offline
Primavera P6 stacked histograms are powerful tools. I recommend to use it for cost and resource loading purposes. Here you can find an article explains stacked bar charts and primavera stacked histograms
https://www.projectcubicle.com/stacked-bar-chart/
