Resource importing and exporting from P6 to Spreadsheet
6 replies [Last post]
vivek t
User offline. Last seen 7 years 12 weeks ago. Offline
Is there any way I can export the assigned resources to activities from Primavera Programme to excel and then import the same resources on a modified programme with similar set of activities and quantities rather then assigning each resource individually to all the activities again. Please help.
User offline. Last seen 2 weeks 3 days ago. Offline
Yes.
Project A:
Activity X = Description Abc
Activty Y = Description 123
Activity Z = Description xyz
Project B:
Activty 1 =Description Abc = Activity X
Activty 2= Description 123 = Activty Y
Activity 3= Description xyz = Activity Z
Do the workaround in excel to create it.
vivek t
Thank you all. Thats helpful. Could you guys help me with some more things. The Activity IDs in the old program does not match with the Activity IDs in the updated programme. Rather then changing each activity ID, do I have any option of doing all the activity ID changes in one step?
vivek t
Thank you all. Thats helpful. Could you guys help me with some more things. The Activity IDs in the old program does not match with the Activity IDs in the updated programme. Rather than changing each activity ID, do I have any option of doing all the activity ID changes in one step?
Yes.
Project A:
Activity X = Resource abc
Activty Y = Resource 123
Activity Z = Resource xyz
Project B: Modified
Activty X =Resource abc
Activty Y= Resource 123
Activity Z= Resource xyz
Kannan CP
User offline. Last seen 14 weeks 5 days ago. Offline
Vivek,
1.Make a copy of the existing programme in the same system and do the required modifications in activites and WBS.
2. If you want to have separate resource identification for the new project, follow the below mentioned steps (i hope it will work)
a. Export the existing file and import it(during import, put "insert new" for the resources in the modification area)
b. It will create a new set of resources similar to the existing project, and add some project ids for each resource.
Kannan
yes you can do this
1. first you have ot make sure that the same activity numebrs exist in P6 in the schedule that you want to import into.
2. you will need to change the WBS name from the exported file to match the name of WBS for the new wbs to import into.
3. The same resource must exist in the resource dictionary. If it is on the same machine then not an issue.
