Disappearing Budget values
John Revere
User offline. Last seen 7 years 26 weeks ago. Offline
The resource calendars are a mess and Im wondering if this is an issue as when an actual start date is entered to status the actvitiy the resource cost value is erased immediately? any ideas?
User offline. Last seen 9 weeks 1 day ago. Offline
Try to make changes of the "Duration Type"
John Revere
The resources are not disappearing it's the budget when you click on the actual start of an activity.
John Revere
The resource stays it's the budgeted value that changes to zero.
John Revere
No it's not being reduced by 8. It automatically disappears or changes to zero when you click on start date. I'm thinking when they setup P6 initially they must of clicked on a box to reset the values to zero. They have assigned resources and wonder if again there is a calculation setting that is causing the disappearance.
Jimmy Xie
User offline. Last seen 8 years 19 weeks ago. Offline
Dear John
How is your resource "erased"exactly?
Is it erased as 8 times less compare to the original budgeted unit?
