Primavera P6 V8.3 not responding for page setup
6 replies [Last post]
Santhosh kumar Na...
User offline. Last seen 7 years 20 weeks ago. Offline
Hi folks
Recently upgrade the from P6V8.2 to P6V8.3, everything fine and works well, but when ever i tried for page setup or print set up, it is not responding.
I can take print with default set up, I can't change footer or header etc my system is Window 7, 32 bit (it is not responding..just revolves and hangs)
Please support and thanks in advance.
Ahmed Aziz
User offline. Last seen 9 years 22 weeks ago. Offline
Dear Kumar,
As I have understood you have problem with placing the header and footer, it is a problem with th P6 V8.3 it gets stuck and won't apply the changes you have made.
However, there is a walk arround. chose the part you want to modify and then change the text alignment and apply, you will notice that the changes have been applied.
Aziz
It is the software compatability issue!, resolved by re-installing (you have to uninstall from registery also prior to re-install)
Ahmed Ali Memon
User offline. Last seen 9 years 26 weeks ago. Offline
Hi Friends,
  • I am using Primavera P6 r 8.2, few Projects are vanished/hidden from EPS. I can’t see them even if i am making new project with same ID & Name. i have tried with fillters but still no result.
Now, i am facing new problem as well, that has stuck me for any new job
  • I am adding new Project in Primavera Client. I am unable to add new project, and receiving message “WBS record was already added by another user. The other user’s data will be used”,
Please take me out from this trouble. I will be very thankfull
Thanks & Regards
Ahmed Ali
Ahmed Ali Memon
Hi Friends,
Thanks & Regards
Ahmed Ali
Siva Kumar
User offline. Last seen 6 years 15 weeks ago. Offline
Santosh
Regret to see such a response from Ameen.
The issue which you mentioned is something related to the software compatibility with the OS and Bit. I too face this problem while working on widows 7 PC sometimes suddenly. I export to Windows XP PC and do the editing.
If you have a license[for support services], place a service request with oracle and they should be able to help you. And share the fix ;-)
Ameen Pasha
User offline. Last seen 11 years 14 weeks ago. Offline
Dear Santhosh,
Hope you are doing fine, it is better you join basic course to brush up your knowledge about P6 etc.
