Different Total Float importing same .XER in two different computers
11 replies [Last post]
Natalia Barroso
User offline. Last seen 8 years 2 weeks ago. Offline
Last week I sent a .XER file and a PDF of the schedule to my Client,  yesterday Client call me arguing that the critical path was different in PDF from P6, after a few hours we realized that the problem is that in his computer the total float of the activities is different to the ones I have in mine. I imported the same file in a stand alone database and the total float remains the same that I have in my Company database. Does anyone has have this problem before?.
Natalia
User offline. Last seen 6 days 23 hours ago. Offline
check the calendars see if you are using the default calendar and see if the default calendars are the same .
Hossam Kouta
User offline. Last seen 8 years 19 weeks ago. Offline
i have the same issue any one find a solution
Hossam Kouta
1. go to admin then admin perferences and make sure that the time periods are the same the default is
8.0 40.0 172.0 and 2000.0
2. if they are the same make sure that when you are importing the xer fle that during the import that you mofdify the import oprion and bring in the calendars.
3. also when you schedule the project make sure that you are both using the same scheduling options should be reatained logic.
4. turn your TIMES (edit, Users Preferences,Dates,Time) on make sure that the data date TIME is the same.
User offline. Last seen 19 weeks 17 hours ago. Offline
Perhaps using multiple databases can help keep control of the situation on the issues that seems keep piling up.
Someone must keep control of the pack and play the portfolio leader, each client shall be the leader of his own portfolio. In this way when having multiple portfolios and clients you will be able to meet their individual needs.
I do not believe use of multiple databases will completely eliminate the issues but might be better than total chaos.
Ahmed KHR
User offline. Last seen 7 years 20 weeks ago. Offline
Natalia, Did you find a solution to your issue? If yes plz share how you fix that.
Ahmed KHR
Thank you Mike and Ronald.
Kannan CP
User offline. Last seen 50 weeks 5 days ago. Offline
Mike,
Regardless of the Global or Project Cal, export the file and importing it to another computer will display it. Every month I am forwarding my P6 file to client which has a global calendar.
Kannan
Ronald Winter
User offline. Last seen 4 years 16 weeks ago. Offline
There is also the issue of the Hours to Days conversion factor.  That can be set in two different places, depending on the system setting.  The conversion factors must be the same in both computers for the durations and total float to match.
User offline. Last seen 30 weeks 6 days ago. Offline
Hi Ahmed
In P6 there are Global calendars and Project Specific Calendars.
If you export a project with a global calendar it will not be picked up on the other computer.
Just one of the joys of working with P6.
Ahmed KHR
Hi Natalia,
It could be calander (Not the same one), or scheduling option, longest path or total float.
Actually our consultant don't get the same calender when he import our files and I don't know why????
Ahmed
