Primavera Critical import issue
User offline. Last seen 6 weeks 4 days ago. Offline
During Import of XER file the appication is intercepted. Then it is not possible to start P6 at all.
Log file:
Bad Data Row for table UDFTYPE
UDF_TYPE_ID = 828
TABLE_NAME = TASK
UDF_TYPE_NAME = user_field_828
UDF_TYPE_LABEL = OLD_MS_UID
LOGICAL_DATA_TYPE = (null)
SUPER_FLAG = (null)
INDICATOR_EXPRESSION = (null)
SUMMARY_INDICATOR_EXPRESSION = (null)
I understand that it could be something wrong with the XER file but really surpriseby that P6 is so unstable. It is absolutelly abnormal that one bad import can kill the whole sysem.
It is something easy to fix or the only way is to re-install P6?
8616
User offline. Last seen 1 day 18 hours ago. Offline
It is an XER issue, not a P6 issue. The XER file contained bad data, preventing P6 from importing to avoid data corruption. It is an easy fix if you know how to read XER using a normal text editor, XER manager, or XER parser. You just need to remove the UDF type and UDF value that is causing the error. If you wish, you can send me your XER, and I can fix it for you.
david kelly
User offline. Last seen 2 weeks 4 days ago. Offline
hmm logical data type of null is not valid. Someone been editing the XER file?
david kelly
david kelly
Frankly, Alex, if you are stuck....... I will have a look
david kelly
