Fixed Works and Duration
6 replies [Last post]
mimoune djouallah
User offline. Last seen 5 years 51 weeks ago. Offline
hi ms project expert.
is there any option to assign a fixed amount of works and a duration to activities,
basically I have the amount of work for the activities from the estimation software, and I want the duration to be independant from the resource assignement is that possible in ms project ( something like fixed duration & units in P6).
regards
mimoune
ps
I am not trolling here, for some reason the client wants ms project and i have to live with it :(
mimoune djouallah
sorry for not being clear ( as always)
so basically i am using fixed duratin and effort driven is off. the option Updating task status updates resource status  is off.
i don't want ms project to change the work value if i change the duration, and i don't want ms project to change the actual work too and the remaining, everything should be independant ?
Evgeny Z.
User offline. Last seen 1 year 50 weeks ago. Offline
you can't do it in MSP directly (you need Spider for this). For MSP duration would be driven by average productivity of 2 resources.
User offline. Last seen 20 weeks 3 days ago. Offline
Evgeny,
If resource A installs 100 bricks in one hour and resource B installs 50 do work and effort is the same for each resource?
How do you plan within MSP for different resources working at the same time on the same activity same work hours but each with different productivity?
Evgeny Z.
mimoune,
I am a bit confused. You write:
...something like fixed duration & units in P6...
..i don't want ms project to change the amount of works too,..
I am not familiar with P6, but effectively you want Work, Units and Duration to be fixed. Is it correct?
mimoune djouallah
Evgeny
thanks, i am already using the fixed duration, but i don't want ms project to change the amount of works too, maybe using a custom field my help ?
Evgeny Z.
mimoune,
not sure 100% that this is what you need, but the straight answer is that you need to use fixed duration task
http://www.slideshare.net/Shelleyb758/ms-project-2010-task-types-best-uses
