MSP2007 Printing Extra Page
Tony McClennon
User offline. Last seen 1 year 11 weeks ago. Offline
I did post with this problem some time ago, but didn't have any success with the suggestions. Although the need for the previous project went away, I am having the same problem with another project.
In the page setup I select "Fit to: 1 page wide by 1 page tall" but the plan prints 1 page wide by 2 pages tall.  In Page setup I have set up the "Fit to:  1 page wide by 1 page tall" it still prints 2 pages with the last task on the 2nd page.  No matter how many pages tall, it always prints an extra page with the final task on it.
Have tried setting the timescale to print to end of page on and off, and have also checked there are no page breaks lurking.
Would be grateful if anyone has had this problem and has reolved it successfully.
Many thanks.
Tony McClennon
Quite bizzarely, I have discovered that the problem may also be caused by not having the ID field as the first column in the table. I tried copying the task data to a new file, and kept saving after each change I made. It was only when I amended the table to take out the ID column that the printed output put the final task on a new page. When I went back into the table, added the ID column back in and set the width to zero, it went back to one page!!!
Tony McClennon
Hi Alexandre,
This happens in specific projects. Unfortunately if I try and scale manually, it does not "fit" the output to the page but only prints on half or 2/3 of a the page.
Fingers crossed I will find a way around this.
Many thanks.
