Date Range Filter
Rohit K
User offline. Last seen 5 years 23 hours ago. Offline
Guys,
I am using MSP 2007 Pro version standalone version installed on desktop. Can any one of you help me as for one of my schedule the date range filter is not working. For other schedules they are working fine. Not able to understand the cause of this problem.
Does preparing in MSP 2010 and saving it in 2007 verison have any effect as I guess my contractor might have done it so while submitting as he has got 2010.
Rohit
sudarshan singh
User offline. Last seen 5 years 35 weeks ago. Offline
Reinstall it and u may get .
Ellen Lehnert, Mi...
User offline. Last seen 7 years 5 weeks ago. Offline
Switching back and forth between 2007 and 2010 is not a good idea.  You lose a lot of data going back and forth.  Some of the calculations are not the same between levels  - for example assignments.  You have features and fields added to 2010 that you lose when you save down and don't get back when you convert up.  After you do convert a few times the file will become corrupt and unusable.  If you have booth versions installed on the same system without them being installed in different directories you will see problems like filters not working, etc.  I would uninstall both versions, pick one and install just that verision.
Ellen Lehnert, Microsoft Project MVP
www.lehnertcs.com
mukunda y
User offline. Last seen 11 years 42 weeks ago. Offline
Rohit,
Uninstall & then install u may get it
