MSP 2010
8 replies [Last post]
Susiri Leelaratna
User offline. Last seen 7 years 22 weeks ago. Offline
When I print out MSP2010 file of 2.7 MB, the file size increases to 99 MB during transmission to the printer (The output at the printer indicates the file size).
It takes about 15 minutes to print.
What is the reason for this?
Can anyone help?
Leonard Esber
User offline. Last seen 9 years 37 weeks ago. Offline
Hi all, just want to ask how many columns available in MS Project 2010?
K L KAMESWARI AK...
User offline. Last seen 11 years 15 weeks ago. Offline
Susiri,
first convert the file into pdf and then give a print
Evgeny Z.
User offline. Last seen 1 year 25 weeks ago. Offline
RE
When I use "Group by summary" in MSP 2010, the summary task in the DURATION FIELD does not calculate as previously did in MSP2007:
Duration in Summary Task (MSP 2010) = Duration of the sub task with MAXIMUM Duration
Duration in Summary Task (MSP 2007) = Latest date of any sub task - Earliest date of any sub task
How do I overcome this problem in MSP 2010?
I think you need to use scheduled duration field.
I think this has been discussed here:
http://www.planningplanet.com/forums/microsoft-project/534833/group-duration-summary
RAJA GHOSAL
User offline. Last seen 5 years 46 weeks ago. Offline
After updating the project progress I want to see expected finish date on a current data date.Can anyone help me in MSP 2010.???????????
Niek Zonneveld
User offline. Last seen 6 weeks 3 days ago. Offline
Susiri,
This is clearly an error. I've tried to produce similar results with formula's (ProjDateDiff, between earliest start and latest finish date in the summary) but that doesn't work (like it should) either.
If you (temporarily) remove your baseline, you can use Duration Variance instead but that's obviously not the way to go in the long run.
H.T.H.
Susiri Leelaratna
Susiri Leelaratna
Thanks Andrew.
We have found the problem. It was in the printer software.
Andrew Dick
User offline. Last seen 9 years 3 days ago. Offline
Susiri,
This problem may come about by having information below your project.
In the activities view go to the bottom line. From there highlight everything below it to the bottom row, then clear or delete these lines to remove any data that may be in there.
This should hopefully fix the issue.
Andy
