how to see the predessor and successor form in MSP?
Pranab Kumar Deb
dear all ,
can anyone advise me as to how the pred/succ form seen in MSP.
regards
deb
Pranab Kumar Deb
Dear Darren,colin and Pinan,
Thank you very much for the tips, this is exactly what i needed , same view of P3.
regards
deb
Darren Kosa
User offline. Last seen 8 years 2 weeks ago. Offline
Hi Deb,
Another variation for seeing predecessors / successors in a visual format... as if you need another ;o)
Window > Split > and then click anywhere in the Task Form
Then you need View > More Views > Relationship Diagram
Whenever you select a task in the Task Entry you will also get a graphical representation in the Split Window.
Might be a bit meaningless for most, but it’s helpful for some.
Darren
Colin Blair
User offline. Last seen 15 weeks 2 hours ago. Offline
Hi Pranab
Try Window / Split
Right click on the bottom window - select Predecessors & Successors
This will give you the Task Form
For the Task Details Form -
(make sure you have clicked in a field in the bottom pane)
View / More views
Select Task Details Form
Apply
(Note-You can set up a custom view which will retain this view)
Is this what you’re after
Colin
faisal afsar
User offline. Last seen 12 years 41 weeks ago. Offline
Dear friend
Double click on any task a tab will appear go to predessor and u can see it
Faisal
PINAN T.
User offline. Last seen 6 years 36 weeks ago. Offline
In Task Information only, or use Column..
