Critical path
Ahmed Ewis
User offline. Last seen 9 years 24 weeks ago. Offline
i have contractor and all the time he is complaining that i delayed him behind the schedule so he said for one activiy is on critical path how can i use MS project file to see if he is correct or not or to see if this activity is critical or not
Brian Ultican
User offline. Last seen 18 years 2 weeks ago. Offline
Are you suggesting that the use of deadlines gives different results each time you use them? I have found the impact of a deadline on task slack to be quite predictable.
James Griffiths
User offline. Last seen 16 years 25 weeks ago. Offline
Ahmed,
Just a word of advice. Critical path calculations, using the software, are notoriously unreliable. If you have used any date constraints or "Deadline" dates etc, all these will be calculated as part of the critical path. If your schedule is fully networked and linked, and allowed to "float" with no "deadlines", then you have a reasonble chance of getting a reliable result.
HTH.
James.
Brian Ultican
You can insert the field called "Critical" into the gantt chart. If it is ’Yes’ then the task is critical. You can also look at the Detail Gantt view to see the Critical Tasks as Red bars on the Gantt chart.
