Master Projects and Sub-Projects.
Forum Guest
User offline. Last seen 50 weeks 1 day ago. Offline
I am trying to consolidate a whole Engineering Department with MS Project. As you can imagine we have 80 or so projects and all have their own resources. I have split out the projects by engineer and when I look at the consolidated histograms they are all separate entities. Ie If a resource appears in 2 engineer’s jobs that resource would have 2 histograms. Is there a way to consolidate data onto one histogram using MS Project. This is one advantage P3 has over MS Project. Help please! Thanks
Will Russell
User offline. Last seen 12 years 24 weeks ago. Offline
If you use a resource pool, a project that has only resources and no tasks and share these resources (Tools - Resource Sharing - Share Resources) between your projects then the resources should have only one histogram.
Will
