Delay Analysis
6 replies [Last post]
Sunil Babu
User offline. Last seen 5 years 16 weeks ago. Offline
Dear All,
Currently I am working in a DG Sewerage project, our task is to calculate the delay for each shaft.
My question is that how to link the delayed days with the total float of the BL . Also other than window
analysis is there any other methods of delay analysis which best suited for this project.?
Your comments will be highly appreciated.
Sunil.
Sunil Babu
Hi Mike,
Thanks a lot for your valuable reply..
Sunil
User offline. Last seen 1 day 11 hours ago. Offline
Hi Sunil
The same principles apply no matter who is operating the rigs.
Sunil Babu
Hi Mike,
Thanks once again for your valuable reply, another problem in in the change of logic is that
there are defferent contractors operating for these rigs and we have to allocate them accordingly
depends on various conditions..
Sunil.
Hi Sunil
So you have 5 rigs deployed on a number of shafts.
So when rig 1 has finished it moves on to shaft 6 and so on.
You should arrange the shafts into groups of 5 and link Shaft 1 to shaft 6 > shaft 2 to Shaft 7 accordingly.
You can also set up rig resources numbered 1 to 5 and allocate them to the appropriate shafts.
Now if - say - shaft 3 is delayed then rig 3 will be late starting shaft 8 and all of rig 3 allocated shafts will be delayed.
However you must be prepared to rearrange (mitigate) the sequencing so Rig 3 could go to shaft 10 and rig 5 drop onto shaft 8 etc.
This is done by adjusting the logic.
Sunil Babu
Hi Mike,
Thanks for your reply, actualy this is a deep gravity sewerage project and the programme
was made based on the logic of rig movements, for example five rigs are in operatin under which
the total shafts are diveded into five groups , Various facts affecting the delay such as
delayed ifc drawings,traffic permits, rig break down, excavation in hard rock etc.
Can you explain further on "knock on effect" based on these factors..
Sunil.
Hi Sunil
I do not know what a DG Sewage Project is but I am assuming that it is not important.
It is easy to calculate the delay for each shaft by impacting the delay event that caused the delay and then comparing with the actual progress.
Unless there is some logic linking the shafts to the completion date then there will be no "knock on" effect from each standalone shaft to the rest of the programme.
So in order to see the effect of float on the Baseline Programme then some realistic logic has to be in place.
This logic could be physical or resource driven or both.
If you are putting it into an already approved programme you will be accused of rigging it.
