Asta Powerproject BIM
Hi All,
Are any of you using the BIM feature in PowerProject? I'm trying to, but for some reason, when it opens the IFC4 file, everything is gray? Any tips or tricks would be appreciated :)
Martin
Artur Pilipczuk 👤 Member for 2 years 5 months
In most cases I'm receiving 3d models from Clients in Navisworks nwd format. I'm converting it to ifc 2x3 format using Iconstruct addon to Navisworks. I had no issue with colors so far.
You can try to open ifc file in any viewer and if it is all gray then it's the file's problem.
I'm also receiving ifc files generated by Tekla and also there,s no issue with colors.
Artur
B
Bian Mutang Tagal 👤 Member for 12 years 1 month
Hi Martin,
Normally when we import something into BIM tools and it is gray that means the textures are missing - sometimes the textures are stored as a file that must be imported together. Sometimes, it is the settings used to create the IFC file in the BIM authoring tool that may be the issue - maybe this post I found online may provide some clues (https://forums.buildingsmart.org/t/where-and-how-will-my-colors-be-save…)
Featured Partner
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
