Asta Natural Order Hierarchy & WBS
Peter Mueller
User offline. Last seen 6 years 39 weeks ago. Offline
I have a schedule file for Asta that needs to be imported into P6.
The problem that I am having is that the schedule was created using the "Natural Order Hierarchy" instead of WBS.
Is there a function that copies the "Natural Order Hierarchy" into a WBS and keeps both of them assoicated with eachother?
User offline. Last seen 13 hours 54 min ago. Offline
Hi Peter and Matt Asta Powerproject develops its own WBS system or you can create your own. Any WBS is transcribed to P6 along with the rest of the data. You can then make use of it as usual. Best regards Mike Testro
Matt Mills
User offline. Last seen 6 years 32 weeks ago. Offline
Peter,
I am also having this issue. Did you have any luck on this?
Matt
