Changing format in Text Annotations
Craig Adams
User offline. Last seen 13 years 33 weeks ago. Offline
Hello Fellow Asta travellers,
Anyone know how to change percentage complete if using overall percent complete in text annotations to show % instead of default two decimal places.
Am pointing to overall percentage which by default has two devcimal places, then changed this and refreshed view - annotation did not change.
699
Whilst on this, is there somewhere were we can set default to no decimal places for all??
Thankyou in anticipation!
User offline. Last seen 31 weeks 1 day ago. Offline
Hi Craig
I have just replicated your situation and the 2 decimal default is fixed - I could find no way to edit it.
You can put a text % symbol after the decimals.
Put it on the Asta Wish List for the next edition.
Craig Adams
Hello Mike,
I understand how to change percent to show % in columns, however in this case I am using annotations in the chart area and I have set them to show the percentages.
The annotations do not change when you change the columns, they remain the same with two decimal places. It's the annotations I am unable to change formating of not the actual percentage column.
Craig Adams
Hi Craig
High Light the coloumn
Right Click and select Format Cells
Select Percent - select 0 decimals
Click OK and you get the percent sign.
