Integrating Maximo and Primavera P6 Webcast
Webcast:   Integrating Maximo and Primavera P6
We would be delighted if you could join us for a live webinar, introducing the Legare Professional package's ability to seamlessly integrate between Maximo and Primavera P6. Thursday 30th July 2015  10.00am - 11.00am  BST  11.00am - 12.00 CET Click here to register
Loading data into Primavera P6 is a time-consuming and expensive process - which typically involves typing the values in manually.  Substantially impacting on organisational efficiency and data accuracy, this task is frequently open to error and can be a considerable drain on planners' time.
Legare Professional transfers key project data bi-directionally between Maximo and Primavera P6. The tool is a simple to use, configurable and very effective application - giving you the ability to load key maintenance data and activities into your Primavera P6 schedules. The Legare Scheduler tool enables automatic data loading at user-defined times. The fact Legare uses the Primavera API, ensures data integrity and that all rules and security privileges are maintained. Webcast Agenda - A live demonstration of 'Legare Professional':
  • How Legare can be used for Maximo integration with P6
  • Live Demonstration of Legare in action (Maximo to Primavera P6)
  • Main features of Legare and the Maximo Connector
  • User defined configurations and mappings
  • Transfer and transform data
  • Overview of the Legare Scheduler tool
  • Case Studies
  • Question & Answer
Here's what else Legare can do:
  • Loads data from any source, e.g. SAP, Oracle, Maximo, Microsoft Project, JD Edwards Flat Files and Contractor Work Management Systems
  • Loads Activity Codes, Costs, Expenses, Resources, Roles, WBS, UDFs and Projects
  • Data Connectors include: XER, CSV, Oracle, Excel, Microsoft Project, Access, and MS SQL
  • Some of Legare's additional modules and functionality include: Forecasting, Automating Imports & Exports, and Dictionary Synchronization
Register Now
Unable to attend?  Email [email protected] to organise a one-to-one demonstration of the software
Thank you in advance for your interest - if you have any suggestions or feedback, please contact me. Further information and connector types can be found at www.collabro-legare.com
Best Regards.
Greig
Greig Duncan
Legare Global Channel Manager
Image removed.
Abkar Bannayan
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
GeoVe
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
