I hope u were able to get through with help these guys gave..... I am in your shoes at the moment and will be needing alll the help on M&E Planning......
19 years
Member for19 years
Submitted by Chris Davies on Thu, 2007-01-18 09:13
I hope what im sharing to you will be relevant to your needs.
Generally, the M & E works in Building construction previously refer to MEP.
Mechanical, Electrical and Plumbing.
mechanical works involve: HVAC, Elevator (Lift in UK), Escalator
Electrical Works invovle: High Voltage, Medium Voltage and Low voltage (depends on the size of the project.
Plumbing Works involve: Water supply system, Sanitary System, Drainage System.
When you plan the activities for building construction (assumming you have completed the design and procurement phase) works, the initial activities involve Insert or rough ins. These are the activities that run parallel with the structural construction (concrte works).
You also plan the installation of hangers, raceways on a floor by floor basis. You take note of the vertical raceways, vertical pipes that runs into the chase alloted for MEP elements.
You take note also the location of mechanical and electrical rooms.
When you work out the MEP schedule always take note on the civil schedule that will give you access dates to start MEP works.
Charlie
19 years 2 months
Member for19 years2 months
Submitted by Tunde Layeni on Sat, 2007-01-13 17:11
Log on to www.primavera.com/services/training.asp,Where you can view various primavera web based courses.Don,t worry if you are familiar with planning principles,you would not have much difficulty making the switch.
15 yearsHello Chrissss... I hope u
Hello Chrissss...
19 yearsRE: Junior Planner Breaking into M&E and P3, Needs Help
Thanks Charlie for the excellent introduction, and Tunde for the primavera link.
Does anyone know of preferably a trusted MEP/M&E website or a book I can refer to in order to gain detailed information concerning the subject?
20 years 4 monthsRE: Junior Planner Breaking into M&E and P3, Needs Help
Hi Chris,
Charlie
19 years 2 monthsRE: Junior Planner Breaking into M&E and P3, Needs Help
