PRMDB-1701-A importing fault code
16 years 3 months
he needs to get the previledges
14 years
were importing xlm via the web interface.
the above imformation was very useful especially column x.
he has noticed a variation but does not have the privaleges to change it at the moment.
Kind regards Craig
i would like some more attention on this as i can't start without having this fixed.
14 years
ok were going through the primavera enterprise.
i have been told we can not do regular imports /experts.
Is this true.
we have togo through the web interface .
The web interface only works to a status report after importing that says failed.
kind regards Craig
fairly urgent now
16 years 3 months
1. the excel file needs to be an xlsx
2.  job_data_x column in the dbo.JOBSVC table not displaying varbinary(max), null as a datatype.the solution is to run the sspm_settings.sql located in the database\scripts\<PM_$Version>\install directory.
To alter the job_data_x column type, run the sspm_settings.sql script against the database as the sa user.
This script can be found within in the P6 EPPM media files at database/scripts/install/PM_<$Version>/sspm_settings.sql
After the script is run successfully, confirm the dbo.JOBSVC column shows as job_data_x (varbinary(max), null)
