Problem Installing P6 8.3
13 years 7 months
I am also having problems installing my P6 on my machine. The folling error is showing:
''Primaver P6 Professional R8.3.2 Setup Wizard ended prematurely because of an error. Your sytem has not been modified. To instal the program at a later time, run Setup Wizard again. Click the Finish button to exit the Setup Wizard''.
Can someone assist please?
Thank you
6 years 8 months
Hello again,
I removed all related files of SQL and primavera and installed again. First I installed P6 and I received same error but I set the database manually by using pmdb$primavera database. It worked. Thank you for your support anyway.
16 years 3 months
can you tell me what the log file says ?
22 years 9 months
Hello,
I presume that you have installed a stand-alone Primavera? "database creation failed" means that the Windows registry and sometimes the hard disk folders are not clean enough to enable the P6 installation to process.
As far as I know and have experienced myself, you will have to:
open the registry by "regedit" and suppress any entry related to Primavera P6 and the existing database; suppress any existing folder related to the same; clean the hard disk and the registry by using some software like Ccleaner
if the above fails, I am afraid you will have to re-install MS Windows
Alexandre
