so basically i am using fixed duratin and effort driven is off. the option Updating task status updates resource status is off.
i don't want ms project to change the work value if i change the duration, and i don't want ms project to change the actual work too and the remaining, everything should be independant ?
19 yearssorry for not being clear (
sorry for not being clear ( as always)
17 years 9 monthsRafael,you can't do it in MSP
you can't do it in MSP directly (you need Spider for this). For MSP duration would be driven by average productivity of 2 resources.
21 years 8 monthsEvgeny,If resource A installs
Evgeny,
If resource A installs 100 bricks in one hour and resource B installs 50 do work and effort is the same for each resource?
How do you plan within MSP for different resources working at the same time on the same activity same work hours but each with different productivity?
17 years 9 monthsmimoune,I am a bit confused.
mimoune,
I am a bit confused. You write:
...something like fixed duration & units in P6...
..i don't want ms project to change the amount of works too,..
I am not familiar with P6, but effectively you want Work, Units and Duration to be fixed. Is it correct?
19 yearsEvgenythanks, i am already
Evgeny
thanks, i am already using the fixed duration, but i don't want ms project to change the amount of works too, maybe using a custom field my help ?
17 years 9 monthsmimoune,not sure 100% that
mimoune,
not sure 100% that this is what you need, but the straight answer is that you need to use fixed duration task
http://www.slideshare.net/Shelleyb758/ms-project-2010-task-types-best-uses
